Group: DynoMotion Message: 8223 From: Toby Rule Date: 8/30/2013
Subject: timing of KAnalog Opto outputs (JP13)
What are the timing characteristics of the opto outputs on the KAnalog?  It seems that when I command the bit high, it doesn’t go high at that instant, but there is typically some delay.  It looks like they switch at discreet points in time, like a clock cycle.  I suppose this is related to the multiplexer speed.
So for high-speed timing with optical isolation,  I presume I need to connect one of the TTL outputs on the KFLOP to my own opto-isolator?
Toby
Group: DynoMotion Message: 8229 From: TK Date: 8/31/2013
Subject: Re: timing of KAnalog Opto outputs (JP13)
Hi Toby,
That is correct. All the data (more than 200 bits) to/from Kanalog is only updated every 90us servo sample.
Direct KFLOP IO can be changed in less than a microsecond.
Toby
